The Horvaths
Young man with a cowboy hat
For those of you considering the FI Tech system or Trick Flow heads, this may be useful.
Mopar Magic
Mopar Magic
I think they didn't give the FI enough time to tune. It could also be a CFM issue.That carb beat the hell out of the FITech. I wonder if it was a limitation of the self tuning or ????
I would think CFM wouldnt be an issue for a unit rated to support 1200 horses. Maybe the guy from FITech will chime in.I think they didn't give the FI enough time to tune. It could also be a CFM issue.
I agree with the tune time, but I have seen this a lot with dyno tests where the carb makes more max HP but you will have better driveability with the injection.I think they didn't give the FI enough time to tune. It could also be a CFM issue.
And a 91 octane 440 with 240cc Trick Flow heads and a 6-Pack.
RPM.........TQ/HP
3500......559/337
3700......551/388
3900......550/409
4100......553/431
4300......546/447
4500......548/469
4700......543/486
4900......548/511
5100......553/537
5300......544/549
5500......543/568
5700......533/579
5900......522/586
6000......518/592.........end dyno run.
RPM.........TQ/HP
3500......559/337
3700......551/388
3900......550/409
4100......553/431
4300......546/447
4500......548/469
4700......543/486
4900......548/511
5100......553/537
5300......544/549
5500......543/568
5700......533/579
5900......522/586
Yes, it is a stock 3.75" stroke 440.Is that a stock stroke 440?
Thank you great to know.Yes, it is a stock 3.75" stroke 440.
RPM.........TQ/HP
3500......559/337
3700......551/388
3900......550/409
4100......553/431
4300......546/447
4500......548/469
4700......543/486
4900......548/511
5100......553/537
5300......544/549
5500......543/568
5700......533/579
5900......522/586
How much compression are you running with the 91 octane? I was considering switching out my Eddys for a set of Trick Flows but the 78 cc chambers would bump my compression past 11:1. I called Muscle Motors and they told me they would port my Eddys for $1700. It would seem to make better sense to just pay the extra 3 or 4 hundred bucks to just go out and buy a brand new set of Trick Flow heads.
I was told by them that the work would include cnc porting the runners, bowl work, 5 angle valve job and installing new valve springs. The cost would include everything, not just the porting work alone. They did not specify how much flow increase would be obtained from the work. I had only talked to them for a short period over the phone so not a whole lot of information was exchanged. I calculated that my compression ratio would be at 11.4:1 with the Trick Flow heads. I'm currently running a 470 stroker with 10.39:1compression, Performer RPM heads and intake, a .509 lift purple cam with 248 degrees duration at .050 lift in a 4300lb C-body with a 3000stall convertor and 4.10 gear.Of course this engine was designed to use the Trick Flow heads, and we wanted it to be able to run on 87-88 octane in a pinch, so it is 9.9:1 compression.
Our 787 HP 451 stroker ran 91 octane @ 11.7:1 compression. Desired service and camshaft plays a big part of the compression you can run.
Curious. Did Muscle Motors predict what cfm flow they were going to provide for their $1,700?
