Thanks to everyone who responded. This site is a great place to bounce ideas off of other car guys!
This question is to Andrew Ryan..... you mention your car runs at a higher temperature, do you know what that temperature actual is? I was always under the assumption that the cooler your engine ran the better, if your running just a little hotter, that is one thing, but if your running 20-30 degrees hotter that is another. I have been driving these old mopars for 30 years and it seems like they always ran hot and seemed to boil over often, I now have a very expensive engine and don't want to take the risk of overheating and doing damage, but even though it may not boil over with the Evans coolant, is the engine getting too hot in those certain situations, like heavy traffic on a hot day? Just trying to educate myself!
I have no experience with the Evans coolant. I have read a little about it and as I understand it, the coolant has a much higher boiling point, but it doesn't have the same ability to absorb heat like water or water/antifreeze mix, so the engine can end up running hotter. How much hotter I don't know, but I can't help but think that if you have an engine that tends to run hot anyway, this isn't going to help. I did find a couple of websites mentioning an increase of cylinder head temperature of over 100°.
On the other end, it takes longer to warm up, which makes sense because it's not absorbing heat as well. I even read of it getting thick at cold temperatures, although I didn't see how cold.
I've also read that where the stuff does excel is in old unpressurized systems. As you know water has a higher boiling point under pressure, so a coolant that has a higher boiling point makes some sense.
It's noteworthy that a lot of what is available to read on Evans is either from their website or is from some Evans sponsored source. I had to go a few pages deep in a Google search to find some objective comments on its use. Here's two websites that I read that seem to spell it out well.
10 Evans Waterless Coolant Problems (Troubleshooting Guide) and
17 Waterless Coolant Pros and Cons This web site is more technical, but it is from a competitor.
No-Rosion Products Technical Questions and Answers
So, after what I read, IMHO, if you are worried about overheating the engine, this isn't the stuff to use. Since there seems to be increased cylinder head temperature, that could lead to needing a higher octane fuel to avoid knocking. With the gas we have to run now, I'd say that's another reason not to use it.
