Pclancy
At the clear risk of abusing my privileges, I come to this forum again with questions. I apologize if I seem to be asking too many questions, but you guys are an incredible source of knowledge and good advice. I can't resist. Let me know if I over do it.
First, an update. The trunk rattle I spoke of seems to be connected with a bad shock. At least that's what my mechanic says. We shall see. New rear shocks have been ordered. KYB gas shocks. That will make the rear shocks different from the front. Any issue? Note the shocks on the car are fairly new, put on by a PO. Other than being blue, I have no idea what kind they are. They look skinny. See photos on the BAT website for 1977 Newport.
Now for the questions:
1. The driver side inside door pull seems to be coming loose. There is now a touch of play. I assume the drill here is to stop using it and then to remove the inside door panel and to diagnose and then fix. Are there any surprises lurking here? Lessons learned?
2. The vehicle has some sort of automatic locking door mechanism that now is on the fritz. That is, when you use the key to unlock the door, the door locks on both sides no longer move, but the door locks and unlocks nonetheless.
But when you manually unlock the door from the inside by pulling the knob up, both door locks move and make noise. But they don't move. Ideas?
3. I had the bright idea of swapping the radio/tape deck out. The radio/tape deck in the vehicle works OK (but the band/belt that changes the channels is loose, meaning that you need to use the buttons to move around and even then the manual tuning only moves a bit here and there). Plus, the darn thing is AM only. So I go to Murray Park, and purchase a radio/tape deck that is AM/FM that he says is from the same year and model. Looks good. He swears it was tested. Belt not loose, and manual tuning works great. Murray says the dash face comes out with only 4 screws, with spring clips on top side, and then there are 2 mounting bolts on radio face, and one nut on the back of the radio, etc. In short he says it's not a big deal to swap it out. Any bits of advice you could share?
The speakers sound OK. I dread messing with the front ones, given their location way up and under the dash. But the two on the rear deck would be easy to replace. Given that these are most likely 39 years old, any advice on what kind of new speakers to purchase?
Thanks again for your thoughts and comments.
