BillGrissom
Any ideas how to better secure the nuts on my 383 exhaust manifold? The passenger side one started leaking recently. I have seen special bolts (12-point?) with retainers, usually for small-block Chevy, but it would be hard and risky to try removing the exiting studs in my head. I am thinking a tab under each nut that you bend to secure the nut or stainless lock wire.
I have had this problem about every 30,000 miles since I owned the car, usually the passenger side. When I last installed the manifold on rebuilt heads 10 years ago, I used lock washers (standard cut ring type), but no luck. As soon as I heard puffing, I tightened a few loose nuts, but the gasket was already damaged. The noise isn't bad, so time to ponder an ideal fix. Anything off the shelf or any "roll-your-own" solutions.
