Mudeblue
I am looking for a fan shroud for a 1965 Fury with has a 383 with a 22" radiator. Everything I find on the internet is for a 62-64 B body and then from 1966 and up for B and C Body. I put in a new aluminum radiator and am currently running a Derale 17" puller fan along with a pusher fan. Tried both with and without aluminum shroud from Derale. I am working with real close tolerances given I have also installed a/c and power steering with serpentine belts. We were able to to get everything installed but the set up does not properly cool the engine. I have spoken with several people with same type car and radiator size and to a person they were running a clutch fan and if they had tried electric fan(s), they have reinstalled clutch fans. In other cases where electric fans were used, different cars, I was informed the Derale just does not work as well as other manufactures; some of which had used Derale and switched to a different brand. In fact, I originally installed a 17" shroud which did not work and I then purchased another 17" with a shroud and did not really make a difference; both Derale. I gave the original 17" without a shroud away, individual installed, engine overheat, pulled the fan, purchased and installed from another vendor which solved his problem. Don't know what is right and what is wrong but I know what didn't work for me.
Having said all that, we are now going to convert back to a clutch fan set-up but I am having trouble locating where to purchase a 22" shroud OR a wondering if 22" shroud from another year/model, B Body, that might fit! Any ideas or recommendations because right now I have a car that looks good but unusable when temperatures here in Arizona get 80 degrees plus and the water temperature gets to 230+ and red lights are not my friend! In the meantime, it just sets in the garage just looking pretty!
