PontiacJim
Decided to do an upgrade to the electronic ignition box (ECU). Did a little research on the different types, factory and aftermarket, and the improvements they offered.
The FBO brand ECU unit seemed to me to be a good choice due to options I was interested in having. I did do a lot of reading on the unit and it appears there is a mix of negative and positive results. Noticed the negative complaints were early on when the ECU was first introduced into the market. Seems it has been improved and upgraded as a result. With a 5-year warranty, how bad could it be?
I liked the RPM limiter as I think this is always a good thing IF you enjoy exercising your car/engine. You may not think about it, but you can over rev an engine if the tire breaks loose on wet roads, sand, ice/snow, or rocking the car to get it unstuck. Me, I like to be heavy on the pedal at stop lights, LOL, which is not much with the stock 360CI, but I am planning a future engine rebuild and higher HP upgrades that will indeed break loose the single traction rear-end. So the Rev Limiter is insurance.
REV Limiter starts at 0=5200 Each click is 200 RPM Increase Last click is numbered 9=7000 RPM
I purchased a "kit" that included the Pertronix coil (which I use on all my older HP cars as well as their electronic distributor conversions), and a means to eliminate the ballast resistor which we all keep a spare in our glove boxes. Extended use of a coil with a non-compatible Primary resistance may cause the box to fail or coil to fail. Must be used with Pertronix 40011 Coil.
Straight forward and simple plug-and-play installation. I think it took me about 1 hour total to swap it all out. Found a weak wire connector on one of my coil wires so I corrected that.
Does it work? I would say it does. The car starts better and it does idle smoother. Seems to run smoother in general. I cannot say if it would run better if I just added a new/better ECU or the hotter coil alone. Figured I could use the upgraded ECU (the one that was on there was an older replacement and the epoxy on the back side was melting away), the added benefits of a hotter coil to improve spark performance, the elimination of the ballast resistor (and the grief when they go bad), and the Rev limiter for added insurance in the future.
Here is the Kit I purchased: FBO Ignition Box / REV Limiter, with Coil You can also get these items elsewhere and check out the FBO website as they have them and other Mopar items as well: FBO Ignition Systems
