One of my current projects, which started out as repairing some rust in the trunk of our 68 300 convertible, mission creeped into also replacing much of the sheet metal in the trunk extensions, both inner and outer sections. I have been wondering if I should add some kind of drain holes or channels to this area. I don't believe there were any drains from the factory, which is probably why they rust out so quickly in that area.
I do plan on rust proofing as best I can with a POR15-like coating, both inside and out, topped off with an undercoating on the outside. Actually, I'm going to be trying out the KBS products for this project. I've had good results with these kinds of coatings, but I know it's never good to have water just sitting somewhere and even the best coatings will fail eventually in that situation.
My biggest concern is that drain holes in that area may actually allow dirt and moisture to enter since they are behind the rear tires where that will get kicked up.
