Floor Mat Manufacturers
Chicago
Has anyone found a floor mat manufacturer that has or will make floor mats for Formals in the factory style loop carpeting? I have a set from ACC that fit nice, but the cut loop just doesn’t look right IMHO.
Thank you in advance.
Almost all of the floor mats out there are much more universal-fit than admitted to, it seems.
Can your existing mats be cut-down to fit better?
If it's honestly factory original carpet, I doubt it you can match anything to it exactly. If it's an aftermarket carpet, like ACC, you chances are better, but it still may vary from lot to lot or if they change suppliers.
What I've done is order the same color mats, only in plush cut pile that is different from the 80/20 loop that I have. It's close so it compliments but has a little contrast. My Barracuda has 80/20 loop red carpet and I bought plush cut floor mats in a charcoal gray that gives a little more contrast.
ACC product is ok but there are luxury floor
mat makers out there and you will have to search online to find the ones that do classics.
Might find a upholstery shop that can make them? Local shop here can make them, I always have them make mats that fit a larger area. They also have the nibs on the back to keep them in place.
