WissaMan
- Joined
- Sep 12, 2018
- Messages
- 598
- Reaction score
- 607
I spent a little time searching the FSM and the 'net and as far as I can tell, it did, but didn't find anything that explicitly said yes or no.
O.K. I guess I can't help you then. I'll only add that you're playing with a 4500 lb car. It's ah Cruiser not a Street Brawler, and the more you tweak on it the more fuel you'll burn. I know of one Yellow '72 Dodge Monaco Long Roof out on the left coast "somewhere" that's running two 24 Gallon fuel cells, one each rear quarter because he can't make it on one tank full to get him from Phoenix to LA, lol. Have fun with your ride no matter which way you jump,You own the title too I assume? JerIt's not so much about any year in particular. Here's why I was asking --
The 68 300 we recently acquired had the 440 "converted" into a TNT by the PO. I put that in quotes because I don't have hard facts about what was done, but according to him, he had the engine out and had a cam installed that had specs similar to the OEM TNT cam. The engine also has the HP exhaust manifolds, dual exhaust w/ crossover, dual point distributor, and a Holley 670 cfm carb (it's a Street Avenger I'm pretty sure). The car, btw, has a 3.23 rear and 4 speed.
I'm basically wondering how much benefit, if any, would be acheived by going with an aftermarket dual-plane manifold and a 750cfm carb. I read that the Six Pack's 3 carbs gave a total flow of 1200cfm so it leads me to believe that this engine might turn out some extra ponies if I increase the flow. But it's running really pretty well right now so I don't want to upset the apple cart for just a few HP if that's all it would net.
'68 had a Holley carb for the 350HP version and a Carter AVS for the 375HP version.It's not so much about any year in particular. Here's why I was asking --
The 6BBL carb setup was not offered on Chryslers, but even though it was rated 1250 cfm, dyno results with the stock configuration on the 6BBL engine showed a max of about 925-950 cfm. The stock heads, cam and exhaust limited the flow to those numbers. Significant modifications to the engine were necessary to get to the 1250cfm potential flow numbers for the 6BBL setup.
Thanks for all the info, and point taken BigBarneyCars. I'm not looking to go crazy, but also want to make sure there's not some easy HP being left on the table. If the stock 440HP had a 800 cfm carb then it sounds like there probably is.
I had replaced the 4160 in the other 300 (440 non-HP) with a Holley Street Demon 750 cfm. It sounds like both 440's will be happier if I swap the carbs.
The street demon is a much improved carb from the 4160. The standard 440 should be more than happy with that unit.
From the 1968 Chrysler/ Imperial FSM page 14-45 & 14-46
Holley Model 4160 engine 440 Cu In.
Carter AVS Series engine 440 HP
A little tricky to find, but it's there...
