Fury info
mopar Joe 65
Tremonton, utah 84337
Brake question, i plan on converting my drum brakes to disc on my 65 fury, should i go with a power brake booster or leave the manual setup on it ?
Pretty sure your gonna need a power brake booster as you would need a huge amount of pedal pressure to run discs. That and a dual master will be necessary.
You will definitely need a booster. The manual system in your car now won't exert enough force.
From my research, it probably not worth switching the rear brakes. The fronts do most of the work and changing the rears creates a lot of work and expense to make the parking brake work properly.
I bought my kit from Stainless Steel Brakes. They say I should have them in a couple more weeks (built to order - 4 or 5 weeks lead time)
