Fusey lower ball joint rubber boot source?
66l78rat
troy mi
Doing a 73 disc conversion,lower ball joints are good except 1 rubber boot has a tear n would like to replace with new rubber.Anyone know where I can just buy the rubber boot? Part #?
I don't know about 73....have to check part numbers but I know the 99 Dakota ball joint has the same part number for the boot as the 67....can't purchase the boots alone. Discontinued. Those ball joints are like $15 on rock auto.
Swish,thanks for the info!! If they are $15 per,$30 for 2 pieces of rubber sounds expensive but a lot better than replacing both ball joints,I will check it out.
Craig,I'm at work,can I call you around noon tomorrow?
Just seeing this now -- you could have called today, but didn't.... You (or anyone) can call anytime...
I am around 9:00 A.M -- thru 12:00 Noon; then I go to breakfast... I do not have a show this weekend -- so I
AM around tomorrow morning.... Call....
Yours, Craig......
Hi there, same issue with my ‘67 Monaco Wagon. New full rebuild set is hideously expensive. I’m struggling here in Scotland.
Craig, Got any pictures of the Ball joint seals ?
Upper & Lower. I need some for my '66 Imperial, Thanks
I also did a 73 disc brake conversion on my wagon and needed the lower ball joint dust covers. I got mine from Summit Racing. Energy Suspension part # 5.13102G Marked Chrysler Ball Joint Dust Cover. came in a package of 4. Box also has a bar code SKU # of 03639-36824 not sure which number you will need . They worked perfect. hope this helps.
