Am glad to have pics: PM me and send em. Or PM me and I'll give you my email. Thanks, Jer
Since I don't have a lift now, can the anchor bolts be drilled/installed after the concrete pad is laid down?
Rat wall is a good idea! Thanks. Don't need to keep out cats and squirrels, only to have other rodents burrow under.
Lithonia lighting LED, 4 foot Strip Light, 4500 lm, 50 W, 50,000 hour rated life, 4000 K
This is a small garage upgrade, but if anyone is having trouble seeing the socket measurements on the side of your sockets, it may not be your glasses. I had gotten to where I could go over to my toolbox, pull out my socket rack, but I couldn’t see the sizes. I was having to walk outside in the sunlight to see. So I installed one of these 4 foot LED light strips over my toolbox. They were about $40 each from Home Depot after my 10% veteran’s discount. The difference is like night and day. I walk over to my toolbox, and now I can see every tool size even on the quarter-inch sockets. I used 12/2 RomeX cable to install it. If you’re over 50 this is a highly recommended investment. I was impressed enough that I actually went and bought 2 more to really light up the area. Price is competitive with ebay sellers too.
The LED strips don't disconnect from the housing, which is a pain, but you can devise different ways to hold them up while you install housing and wires
Before
After
The wire way cover/light strip pushes onto the housing box. It has 3 slots on each side which match up to corresponding size bulges on the side of the housing. This does not work well for a firm attachment all the way around, but it's nothing small drilled holes and short screws can't fix.
