Garage Floor Input
jollyjoker
Ohio
Greetings Friends! Need to select a color/pattern for garage floors (new construction). Will be epoxy/pigmented flakes. Any suggestions as to colors that work well, anything to avoid? (Obviously, don't want a bunch of little black flakes, if you're gonna be dropping nuts, bolts, etc!). Thanks in advance for any/all suggestions!
Loose a small screw, bolt or washer and it seems to blend into the floor. It is a contradiction, I know. One would think you could see better if it had flakes, but alas it is not. The flakes almost act like camo. lol
Then of course you find it 2 weeks later when you dont need it anymore. :rolleyes:
Just keep it plain concrete...no coatings. I put a "sealer" on my new shop floor after it was recommended that I do so, told the guys at the concrete company what i was going to use the shop for and what would be likely to fall on the it...gas, oil and other petroleum products and they recommended a product, Made by Euclid Chemical - Diamond Clear 350. I put it on and the only thing it will protect against is oil products, everything else like gas, solvent or brake clean causes the coating to get soft, sticky and tacky and then discolour and re-harded with dirt, oil, hand or boot prints and other crud in it. Also when it gets wet it turns into a friggin sheet of ice...seriously WTF!! :(
Bare concrete, if you plan on actually doing any work in the shop. Sealers are/can be slippery and the over the counter epoxies are pretty much worthless. Warm tires, grease, gas etc will have that shiny new epoxy looking pretty sad in a short time. There are commercial grade coatings but they're expensive and to me, not proven for long lasting durability.
Hmmmm now that you mention it, on Jay Leno's show, the floor where he exhibits his cars is nice and shiny.... where they actually work on them... not so much. LOL
I have been told by more than one concrete contractor that you do not want to put any type of paint or coating on new concrete.
My preference and what I did in my last garage and my current garage is to put down garage floor rubber matting covering the entire garage floor. It comes in 7.5' wide rolls and is available in various lengths. I went with black and a coin pattern with my current garage. It makes for easy cleanup and also serves as a moisture barrier. Just my 2 cents on the subject.
personally If I wanted a nice clean looking floor I would pay extra for it to be smoothed and polished...but after having done the epoxy on a garage and watching it peel months later or discolor etc...I will never do it again. It also sweats in cold temps and gets slippery.
When I was working, a manager decided that it would be better to coat the hangar floor with an epoxy coating. I have no clue how much was spent, but when it was done, he gloated on how good it looked.
Keep in mind, this hangar housed about 5 or 6 A-3 Skywarriors.
Within a week of being used, the coating was peeling off and it turned into a giant mess.
My shop floor has a smoothed concrete floor and it is great.
From what I've seen, if a coating is desired, the key things would be "fully cured" and "grease-free". Our former service manager decided to get the shop floor coated, using a generic light gray color. Looked good, BUT it was very slippery when damp or with any oil on it. At that time, the building was over 15 years old with a "used" floor. A few years later, some areas had to be re-touched, after another pressure-wash cleaning. Stayed stuck, then.
Before that, when they built the then-new body shop, there was a covered ramp on one end. He had it "clear-coated". Was very slippery with any moisture on it. Several employees slipped on it. Wrecker drivers couldn't back up on it, either, without much tire slippage . . . most gave up.
About two years ago, somebody the dealer knew sold him on a new coating for that ramp. So they pressure washed it and installed it, with some grit in it. Turned out better than we ever suspected! Even without the grit, it's completely non-slip, period.
One of our car club members had a shop with the same color coating. It was NOT slippery when wet or oily. Looked the same. Obviously some differences in brands or textures!
In my new (2 years now) 50x40 building, the concrete is "as installed". Was nicely smooth finished. Tire tracks and "spots" where the cars are parked for a while, exist. I'll eventually p;ut something on it, but from prior experiences, I'll do some intense shopping around to see what has worked best. Knowing that two similar-looking coatings can act completely different with a bit of moisture or oil on it. In getting things ready for the slab, we put a thick plastic sheet on the ground before the concrete was poured, as a vapor barrier.
Seems like that light gray color usually works well. Light reflectivity, easy to see "things" or critters on it, tolerant of a bit of dirt (compared to white), etc. Petty Blue, Desert Turquoise, or Hemi Orange might be "too much color"?
Our shop floor is bare concrete poured in the 80’s, seasoned with every fluid known to man legal & illegal and it looks beautiful when we clear it off & hit it with the zamboni. The only thing harder to take care of than a painted floor is a painted floor w sand in the paint for traction.
Absolutely correct about the sand or "grit" that the epoxy kits provide. You will NOT be able to sweep the floor with a push broom because of that traction. Dirt pretty much stays put as you try to push it around.
I have done two 500 square foot garages using Epoxy-Coat (Tan once, Light Gray another) and have had good life with it. No, it doesn't stay gleaming forever if you do the work us car guys typically do, but it's still decent and reflects a lot of light (bare concrete sucks light out of a room, IMO). If your garage is merely a parking place for a car and you don't do repair and resto work, it will look like a showroom for a long, long time. Epoxy Flooring Kits | Epoxy Coatings & Paint for all Surfaces | Epoxy Coat I'm sure there are better, more industrial products out there, but their kits work pretty well for a DIY job in a standard garage.
Note: It's all about the preparation of the concrete before you start rolling epoxy onto the floor. I mean a day or two of very careful cleaning, scraping, etching with muriatic acid....time well spent.
As for flakes....you might as well rebuild that carburetor outside on your lawn, because when a spring, checkball, or clip goes launching into the grass you'll have just as much of a chance finding it as you will on flakes. That's until you kneel on it a day or two later and scream in pain, as was mentioned above.
5 years ago I put Rustoleum 2 part epoxy on a new cement floor. I used the tan color and used the color chips. On top of that I used a clear 1 part epoxy with the silica-ish anti-slip additive. This was not an everyday use garage. I sold the house so I don't have pictures. It wore really really well. I used an EZ car-Lift (https://www.ezcarlift.com/ezcarlift_features.html) on it and had no problem. I had no trouble sweeping it clean. Every type of fluid that could leak from a 1970's era mopar (except battery acid) wiped right up. The cars would drip a tar-like substance (undercoating?) on the floor, a little Simple Green took it up. I hope this helps! Enjoy your new garage!!!
This made me Gufaww!!:rofl:
