Blackrifle
1966 newport in a barn for 7 years. I got her started drove her home and started replacing and rebuilding things. Went thru the brakes, rebuilt the carb flushed out an dpressure tested radiator.
Installed new Water pump plugs wires cap and rotor. She ran but barely. started to look into checking the timing, had a buddy help me since I dont know what Im doing. Vacuum canister isnt holding vacuum so I tried to get a replacement. Part number is 3755505. Both parts that showed up don't match up with mine. Distributor has pertronix in it
Any and all help is appreciated. Im even considering ripping it all out and just swapping to a more reliable system.
