1967 Plymouth fury 3
I was wonder if anyone has a ok kinda cheap switch or knows how to fix a switch
The difficulty with rebuilding is tapping back the areas of the metal switch box that are peened over the tabs on the black plastic backing plate. Then you can clean contacts with a sandpaper or wire wheel. My repair of a 1970 headlight switch is detailed here: Headlight Switch Disassemble, 1970-1971 FuryI was wonder if anyone has a ok kinda cheap switch or knows how to fix a switch
No problem rebuilding it. What exactly is it doing, or not doing?
You may have contacts like these. The park portion in the middle stays clean and less grooved because it's used less. The lower portion gets more use and a lot more dirty because of the headlights getting more use.The park lights work but when I flick it on the head lights nothing works
There were 2 different switches that could have been installed.
One with the black plastic body, or one with a metal body (with black plastic back)
Do you know which you have?
