Headlights & Turn Signals, No tail lights or Brake Lights.
deucecard
Concordia, Missouri
My 1966 Sport Fury has headlights, low beam and high beam all work. Front and rear turn signals work. I have no brake lights or tail lights. I have changed fuses, bulbs and brake switch. Didn't help. Any easy solution before I have to run all new wire?
I’m having a similar experience with my 68 sport fury. If I play with the headlight switch so it’s between the park and headlight on slots, then my brake and taillights will work.
This enables me to drive for the time being but I’ll have to track down the issue.
I purchased another oem switch but it’s identical. It could be that both switches have failed in the same way so may have to open them and try to rebuild one.
