gary68plyfury
Hello all,
My 68 Fury III with 383 is Not putting out good/hot air from the heater core and also the temp gauge, for the engine, barely touches the Normal Operating Range in the gauge. I've only seen the gauge ever hit mid-range was in the heat of the summer at red lights. I'm going to put either a new 180 or 190 thermostat in tomorrow to see if that helps it reach normal temp. I know it has a temp gauge but I'm not sure if it works correctly or it's temp. The car was a AC car but it was removed before me.
My question is the routing of the heater core hoses. Right now, the front hose, from the water pump runs to the heater core to the connection to the right.
The connection to left of it runs to the top of the heater core valve. The bottom of the heater core valve run the back connection on the water pump.
Hope this can be seen in my pics.
Is this correct? Does it even matter?
One pic, I've seen on the internet, the front water pump connection goes to the top connection in the heater core valve. Bottom goes the heater core then back to water pump.
Thanks in advanced.
Thanks in advanced.
