rmchrgr
My name is Greg, I'm from Stamford, CT. I'm a Mopar guy to the bone, have a '71 Duster small block street machine for many years and 383/4 speed/EFI '68 Coronet. I'm a long time member over at FABO and FBBO, some of you might recognize me from there. I joined here because I have been helping an old friend of mine build his '66 Fury. Even though it's not mine I have a lot invested in it time and effort wise with him. I figured it would be best to become a member so I could use the site as needed. Glad to be aboard.
A little back story. My friend is not real mechanically inclined. He lives in NYC and does not have his own place to work on his junk. He has neither, tools, equipment or know how. Because of that he has relied on me to help him with all his automotive disasters. He tends to like bigger vehicles and thus far in his short time in the car hobby has gravitated towards mid- '60s C bodies. Previous to the Fury, he had a rust bucket '63 Dodge 880 four door with a worn out 361. The thing was a total beater and spent more time in my driveway than actually driving. After getting it back on the road in 2016, he somehow managed to sell it to some other unwitting rat-rod hipster (for money!) and subsequently found his current '66 Fury.
My friend Aaron doing an intake swap on his '63 880, probably around 2015. This was in my driveway at my old house in Long Island, NY.
Far as I can tell, the Fury is nothing special - small block, column auto with A/C. We presumed it was a Poly from the factory but have never actually verified that. It currently has a wheezy, knocking LA 318 which as stated is coming out for a big block. It did in fact run and drive for a while but has needed a lot of work to keep it on the road. The car was yellow at some point but the P.O. primered over the paint and painted the top black with what looks like roofing tar. He also added the black out hood treatment and Ricky-racer hood pins. Has some rust in the lower quarters and fender skirts and needs a paint job. Interior is "there" but is tattered.
2.26.22
In the summer of 2020, it started having engine problems. The 318 overheated and someone (not me) determined it had a blown head gasket. He took it to a shop he used in Queens and was told it was going to "be a lot" to fix it. I told him I'd be willing to fix it but he would have to get it towed up to my place here in CT. For whatever reason, that never happened. We began discussing whether he should spend the money to have some random shop fix the overheating or spend the money on the big block of his dreams. Ultimately he decided to do the big block swap but since then it's been sitting in a mall parking garage in Queens, NY.
It wasn't totally wasted time because while the car sat we managed to build a stroked 383 (438"). He'd come up to my place on the weekends and I taught him how to build an engine. He loved filling rings and installing Spiro locks. We had a few hiccups along the way but finally completed it late last year. In Nov. 2021, we took it to a dyno shop to break it in and see what it could do. It made around 450 hp and 470 lbs. ft of torque with a 228/232 hydraulic cam, OOTB Stealth heads, Performer RPM intake, Holley 750 and small tube dyno headers. To compliment it he sprung for a full TTi exhaust system from the headers to the exhaust tips which should only help the overall output. It's really a basic hot rod combo that will be more power than he's ever had under his foot.
Fast forward to now. He's managed to gather almost everything we needed to do the swap. Yesterday, 2.26.22, I went down to Queens with a UHaul trailer to pick the car up and start the job. It was an adventure to say the least. The car died in the street and we ended up pushing it onto the trailer with his van. Unfortunately I ended up rear-ending someone in the process. I was 10 minutes form my house too. Not a great idea to suddenly stop at a cross walk in front of a truck loaded with 6,500 extra lbs but who knows what goes through people's heads. We're OK but the front bumper on my Ram has seen better days. Thankfully no one was hurt and the trailer didn't factor into the accident.
Despite the accident I am able to drive my truck without issue and eventually, we managed to get the car into my garage and onto the lift. We even started disassembly and made some progress but around dinner time we called it a day. While underneath, we were being showered with rust and I really couldn't help but notice how crusty the car was. My friend blames the time in the mall garage but in my mind, it's just an old car in need of a complete restoration. I had to be the bearer of bad tidings and tell him that the chassis was not in good enough shape to throw 450 hp at it. It's unclear whether the frame rails are soft or not but I would have been remiss had I not made it clear what he was up against.
Once he got over his initial shock we discussed having the underside cleaned up so we can asses the situation clearly. I'm not doing the job myself, no way, no how, BTDT. The current idea is to get it to a media blasting service about 30 minutes from my house. They offer a pickup and delivery service so unless it's outrageously expensive were going to get that done ASAP. I'm hoping that the uniboody frame rails are OK because they look borderline to me. The front horns of the stub frame also seem like they could be starting to soften but I'm not sure. I believe the only way to know for sure is to get the surfaces clean.
This is what we're up against.
Things like this always snowball. I've made that clear to him every step of the way but yesterday was definitely a bummer. We'll figure it out I guess, just time and money that neither of us have.
Well, that's the story for now. If you've read this far, thanks. See you on the forum.
- Greg
2.26.22
- Greg
