Help! 66 Fury Clutch adjusting rod
SportFuryman
Virginia
Can anyone tell me what the dimensions of the clutch adjuster rod on my 66 Fury 4 speed should be? The one that came on my car is absolutely mangled. Eyelet was almost worn clear through and threaded rod had 3 welds on it where it had been apparently broken. It is the same dimensions as an A-body adjuster rod, 7/16” rod and 7” length. I have been told a B-body rod will work with some modifications but would rather know before buying one. Also, anyone know where I can find a proper over center spring?
