Stargazer
Just now I discovered why I probably keep having issues with the HH motor/switchplate and doors assembly.
Keep getting power from “switchplate switch“ to motor, when that contact should be open. Motor gets hot etc..
I took the motor out of the car, and bench tested it. Works flawlessly. I measured 12V or no Volts at the right contacts.
It turns the bar 180 degrees.
But, and this must be the problem, the headlight doors can only turn 90 degrees?!
This might explain why the gear doesn’t open the contact when it should…
Is it possible that this unit doesn’t belong in this car?
See video’s below
See video’s below
