Highly optioned 1967 300 2dr on cl
Herkenbosch, Netherlands
Older cl ad, just saw it. Original AZ car now in PA. I like the color combo.
http://pittsburgh.craigslist.org/cto/4501107057.html
This is a 1967 Chrysler 300 coupe. Very straight car from AZ. I purchased this car a few years ago and had it shipped from Phoenix to PA. Car is rust free and very straight. Garage kept while in PA, cannot say as far as while in AZ. Car runs great. Power windows, power drivers seat, auto pilot (cruise control, but not operating), power steering, power brakes, 440 engine. New whitewall tires, brakes, radiator, carburetor and bushings. AM Radio is not operable and air conditioning is missing compressor as well as some other components. Asking $6,700, OBO. 412-264-3761, ask for Allen.
Options that are not listed :
Front disc brakes (it is a disc brake master cylinder)
Console
Bucket seats with head rests
Tilt and telescopic steering wheel
I automatically see These models as being green, but now that you mentioned it, this could be silvergray as well on second thought.
HUMMMM. Might be an interesting Slab but I'd think he'd give ah couple pix of the A/C vents to prove his salez pitch. Missing piecez are no big deal. The correct dash? Now that'z ah whole 'nuther enchilada.
i like it either way. If it were here the urge to go look at it would be nearly uncontrollable, and if I went and looked at it and it ran and drove like my mind says it would I'd buy it.
I would say it's mint green metallic based on the paint in the door openings and the underside of the hood. I think the exterior is slightly faded making it look like silver mist metallic. Either way I would like the car in both colors :toothy2:
The dash has the AC vents (look carefully in image 8) and you can see the top of the AC condenser in the engine bay pic
Yup, I saw that before I went HUMMMM. I'd still like to see the ventz. Which one of the ownerz removed it and why? The guy in Az. That doesn't think you can cook ah turkey jes 'cuz it's ah dry heat or the guy that takes it to Carlisle and sitz there in the car, IN THE SHOW FIELD WITH THE WINDOWZ UP IN JULY? The other thing that botherz me iz why would you swap the thermostat nipple for the wrong one and then buy the wrong hose to go with the vertical nipple when everybody into Moparz knowz that the correct nipple iz tipped at 45* to dodge that ole Tecumseh compressor.
Well it is strange but most likely the engine has been swapped, why else would you take off the compressor? Hot wheels need cold air!
You can also see the AC line running over the right fender to the fire wall, the best is still to check it out.
