mr. fix it
here’s The scenario
I gave upgraded my drums to a full 1973 brake disc/ drum on the 66 Polara last winter
I have a decent pedal but it is lower than I like
I can pump the pedal and the pedal comes to a higher height as compared to a single pushing of the brakes
I adjusted the tears thinking that the rear drums needed to be adjusted to get s good pedal height
Not the case here
So I’ve read about the residual check valve helps this situation
My question is that since I am running a rebuilt 1973 M/C it should have the valve built into the M/C
I have also heard that Cardone has removed these during the rebuild process sometimes and not reinstalled it in some cases
Is there a simple way to inspect the MC to make sure it is present?
Not the case here
