How to install rear windshield on 1970 Polara 2 door
adam83
Tacoma, WA
I took my rear windshield out to do some rust repair, body work and paint. I dont know how to install and cant find any tech articles on rear window installs for C bodies. Im 99.9% positive this year of C Body does not use a gasket. I've found replacement trim clips on ebay, but unsure what else I need, like the type of rubber spacers and what type of urethane, and how to install
It uses a butyl rubber ribbon seal. No urethane, no gasket.
ribbon only with no filler ok. Does it compress much? Say, if I mock up the window and see a 5/16" gap between the pinch weld and the window, should I get 3/8" thick ribbon?
