I pulled the trigger on 2019 Scat Pack Charger
Recall for missing a label that was noticed by no one ever...
Common sense tells you that FCA should just mail the owners the missing label but I'm positive their lawyers from the firm Dewey, Cheatem & Howe said the the decal MUST be installed by an Authorized factory trained technician.
And give said job 1.0 hours Labor to the dealer in which said technician gets 0.25 hours... :realcrazy:
The lawyers know that sending the labels to the owner will result in a 5% or less installation rate. They would also need to verify that the owners actually received the missing stickers to install. That's how we roll nowadays.
I'm not sure they're even stickers. Aren't they like silk screened into the visor? Do they have to replace the whole visor? I guess I could go out to the garage and check my Durango. Yeah, right after I finish my coffee.
Graham......
Is there a website that I can check to see if my window sticker finally populated???
My car window sticker is no longer visible at the dealer website.
2C3CDXGJ8KH619361
Two ways to do it Bob. Peter posted the sites a few posts back but I just tried again and no luck. Your Charger just doesn't exist apparently.
If you have the original window sticker take it and a thumb drive to a Kinko's or a copy place and have them scan it to your thumb drive. Best advice I have for you Bob. I cannot explain why some cars do not come up on the digital lookup services.
Thanks Graham!
This is so strange! I will try the Kinko's angle.
Tech's going to get .1 hours to apply a sticker... then reapply free it after the customer complains it's a couple thousands off center.
FYI, the Brampton Ontario Canada Chrysler Assembly Plant is the biggest employer in Canada. The plant has almost 3 million square feet and builds 400 cars a day.
I'm assuming you mean biggest auto plant employer. Windsor actually has more employees than Brampton. Between the two there are about 12,000 employees.
