Imperial to 70 Fury raptop
Hemitom
Newark,Delaware
is there anything on a 69 Imperial that can be used on a Fury ragtop?? does the imperial have rear disc brakes that can be swapped over??
69 Imperial did not have rear disc brakes...that was 74-75. I can't think of anything off hand that would swap over easily beyond basic mechanicals...and even those would require tweaking (The Imperial had a 5 on 5 " bolt circle whereas the Fury had 5 on 4.5".
couldn't i use the front brake parts?? according to Rockauto they use the same rotors. the Fury has Power drum brakes now...
