traintech55
Hey everyone, I decided to make a thread showing how to repair a instrument cluster circuit board. Since this is my first time you may chime in with suggestions. Maybe some of the other guys can do something similar to help the new guys fix our lovely cars.
This has been the curse on our beloved cars, weak pins at the back of the cluster. Very brittle and easy to break.
This is what I used to replace the broken or bent pins. This is a 2 - 56 machine screw and nut. This is the same diameter as the pin, but much stronger.
First step, remove all of the broken pin from the circuit board. Work from the not printed side so you do not loosen the printed part from the board. I used a 1/16 drill bit in a vise grip to do this. DO NOT USE A POWER DRILL. Do this by hand.
Second Step, install the screw and nut, and tighten from the screw side so as not to move the printed circuit. (You can use some dielectric grease to help cut down on corrosion). You can do just one or like I did and replace all of them. Work very slowly and carefully.
Here you can see the printed circuit board after all the pins have been replaced.
Here you can see what it looks like with the harness plug installed. Hope this helps someone when you are up the river without a paddle at 10:00 pm, on a Saturday night.
