When I took my 1965 Plymouth Fury over to a mechanic's house last winter, everything worked more or less OK, except a rough idle. That was the thing I wanted worked on.
The mechanic got busy doing other things, and the car was left sitting outside for about 9 months.
When I picked it up, there were no functioning instrument lights. When I turned the headlights on, they would flicker off. By turning the headlight switch off and on, I could get the lights on for a short while, but then they went out. I had to repeat the process several times to get home.
I am guessing the problem is in the headlight switch? Perhaps it got corroded during all that time in the damp outside?
Should I replace it, or drive the car in the daylight, turning the switch off and one repeatedly? Or could there be another cause?
Does anyone know the best place to get a new headlight switch if one is needed?
