IS there anything more durable than 3M Rust & paint removers
mr. fix it
Canada
I've started cleaning up the firewall and under belly using the 3M rust & paint removing wheels which last about 5 minutes each.
At $10 a pop here at the local outlet, that is a bit on the expensive side of things.
These things do a great job at removing the crusties & surface rust but...
Does anyone have something else I can use to help the process along?
Get a good 5" angle grinder with a cup brush like this...
On customers cars I send everything to be either sand blasted or media blasted. The time it takes to fart around with grinding, stripping or paint stripper makes blasting more cost effective. Does a much better job too especially on rust and undercoating.
I did think of using a sand blaster but the sand will get everywhere which is not a fun thing...
At least I can control the dust field to a certain extent with the 3M wheels.
I will try the cup brush though.
Thanks for the replies!
The chinese version at harbor freight. Mine did the entire passenger rear quarter of my monaco, cleaned a crap load of mill scale off of about 32 feet of square tubing, and some other projects before I deemed it too far gone to continue its use.
http://www.harborfreight.com/4-1-2-half-inch-nylon-abrasive-wheel-94017.html
