greasemonkeyman
I thought this video might help of you've got a sloppy lower control arm on your Mopar
http://www.youtube.com/watch?v=Nwes-SP8u4w
If I was building a canyon carver I would probably do this, on you average street car?
What about the possibility of opening up a Pandora's box?Other than the little bit of weight from the plate no disadvantage
Thanks for the perfect timing, I will definitely be checking mine out.
I know Firm Feel makes a tubular upper control arm for about $400 with the bushings and upper ball joint included,but does anyone know of an aftermarket lower control arm for our C-bodies?
Rick Ehrenburg hates tubular A-arms. If he says they're inferior, then they must be.
Posted via Topify on Android
