65Fury440
So out of the blue, the 65 just stalled, dead, kaput.
I checked the ballast resistor, voltage showing on both sides (12v and 10v).
I checked for voltage at the positive of the coil, 10v there.
Next check was popping off the distributor cap, rotor was in one piece, tab was sticking up.
The pickup gap looked too wide to me, grabbed brass feeler gauge, the gap was at almost .018.
I grabbed the advance plate, there is all kinds of play. I can make it change about .008 in gap with just finger pressure. The adjusting screw is tight, there isn't any play in the shaft,so I closed the gap to .008 and had my helper turn the engine over,the reluctor hit the pickup, because the teeth are uneven. In order to get the longest tooth not to hit, the shortest tooth gap is .015.
Does anyone have an idea how to even up the teeth?
How about getting the plate tighter? It looked like just rivets, maybe hit the rivets with a pin punch?
It's amazing the car ran at all. I thought the big cam was the reason for the idle misfires, it can't hurt to address these items.
Edit- after setting the gap to the above, fired right up.
