My attempt at LED tail lights
300rag
Cochrane, Alberta, Canada
It's been a while, but I'm playing again. I tried something with a spare set of tail light buckets. It's actually pretty bright and you can hardly see the lamp behind the clear lense when it's off. Still fine tuning though.
Do your blinkers flash at the same rate now? I know on motorcycles if you change to LED you need to put in a module to slow the blinkers down to normal.
I`ve installed 1157 LED bulbs from Trucklite in my `69 Imperial and they are the best 100 dollars I`ve spent on her!The taillights blind ya(which keeps the morons back) The brake lights,twice as bright,and the best thing is my front signal lites actually light up. They haven`t been worth a **** until now! Not over taxing the sequential motor so everything works as it should. Hell my amp guage doesn`t even move now when I touch the brakes . Ambers in the front and reds in the rear,yes reds whites were $25 A PIECE VS. $10 FOR REDS!:sunny:
Hard to tell, :laughing11::laughing11::laughing11:
but I believe the Tridon HD12 flasher will work as long as you have at least one standard bulb in the circuit
