I went to take my 68 New Yorker for a ride yesterday and discovered brake fluid coming out or the right caliper upper inside piston. I could see the leak when moving the piston manually on the bench.
The P.O. had installed new front rotors and ( I assume reman) calipers before I purchased the vehicle. I have probably put at least 1000 miles on the car since purchase with no issues.
I removed and disassembled the caliper expecting to find a torn piston seal or a pitted piston bore.
To my surprise the seal looked O.K. as did the bore. I was surprised to see how thin the seal is vs. other calipers I have rebuilt.
I cleaned all parts, reassembled and reinstalled caliper with the proper assembly grease. Vacuum bled the system and checked for leaks. None found. I went for a test drive and again checked for leaks with none found. Checked the caliper before going to work today and again, no leaks.
Is this something that is common on these calipers? A weak spot? A piece of debris between the seal and piston? Maybe the seal was installed incorrectly?
I am not sure I really trust this caliper now. I like the originality BUT if there is a better, more dependable, bolt on option I am all ears.
My wife drives this car also and want the safest set up I can get.
