WANTED need speedo gear
65 cuda
arizona
need a speedo gear from a 78 chrysler cordoba 904 automatic transmission that had a 360 ci/ v8 motor bolted to it. idk if any v8 904 transmission from other mopars with same powerplant will work or has same gear teeth count
i am running 27 inch tall tires 245/60r15
35 teeth------there is a dodge/jeep speedo site---has all the gear ratios matched to tire heights...35.....PATC sells new speedo gears.....35......
