never mind
Sounds to me like it needs refrigerant.
Power goes through the low pressure switch before going to the compressor.
I'll check that tomorrow. I was not sure if the Chrysler had a low-pressure cutoff switch, like newer cars do.
The low pressure switch is within a couple inches of the receiver/drier. Use a jumper wire to bypass it and the compressor will probably kick on if the switch is bad...
