For Sale NOS C Body Parts part two
marty mopar
Feedback: 9 / 0 / 0
3502119 A/C BLOWER MOTOR RESISTOR W/O ATC 1972 25.00
3502714 A/C WATER VALVE 1972-73 50.00
3503123 A/C DOOR VACUUM ACTUATOR 1974-78 40.00
3549061 Differential RING/PINION 2.76 same as 2881466 8 3/4 150.00
3575246 T/SIGNAL SWITCH /TILT same as 3747400 45.00 each
3581794 Right rear DOOR WINDOW FRONT FRAME W/STRIP 4 DOOR HT 40.00 each
3586404 Right DOOR LATCH 1971 40.00
3614997 Right EXHAUST MANIFOLD 3614999 cast on part /400,440 100.00
3621838 A/C BLOWER RELAY 3588317 cast on part 1972 25.00 each
3671934 EXHAUST MANIFOLD/RISER 3671936 cast on part not sure of part # /440 1973
100.00
3695748 HOOD LATCH USE W/O ALARM SYSTEM 1974 35.00
3695808 Right ELECTRIC DOOR LATCH SOLENOID 1974-78 45.00
3698544 Left EXHAUST MANIFOLD 3698546 casting /440 1972-74 80.00
3698544 Left EXH MANIFOLD same as 3744822 3751195 casting 1972-74 80.00
3764852 FUSE BLOCK BASE 1974 20.00 each
3780503 IDLER ARM same as 4014081 1974-75 50.00
3780596 A/C BLOWER SWITCH RELAY 3764511 casting 1974-75 28.00 each
3796287 T/GATE & DOOR LOCK SOLENOID same as 3882206 1974-77 wagon 40.00
3796935 HOOD CABLE 1974 30.00
shipping extra
PM me for more info
