T-revorNobody
1978 Dodge magnum XE coupe - $5,800 - Southborough, Massachusetts
FB Description
1978 Dodge magnum XE coupe. 43k documented miles, 360 motor with upgraded performance intake, lean burn conversion, long tube headers, professionally built transmission and torque converter, Holley 4 barrel, t-stat, newer tires and flow master exhaust. This is an s code special order coupe from factory. All original motor and transmission. Options are a/c (updated). Power windows, power door locks, power steering, trunk release, factory tachometer. Some rust starting to show in areas but undercarriage is very clean. The car starts, idles, runs, cruises and stops perfectly. Suspension is also perfect. Clean title in hand. Serious buyers only. Asking $5800. Open to trades or combo of trade and cash. No test drivers unless you have cash and your ready to buy.
FB Description
