Joseph James
This one is near me. Body rough, but interior looks pretty decent.
1966 Dodge Charger - cars & trucks - by owner - vehicle automotive...
1966 Dodge Charger - Restoration started
400 big block with NEW Pertronics electronics Ignition- This motor starts right up and runs very smooth,HP exhaust maifolds,727 trans,Power steering,8 3/4 rearend with NEW green axle bearings ,2:92 suregrip,NEW 4 wheel disc brakes,NEW disc master cylinder, ALL NEW upper/lower control arm bushings,NEW upper/lower ball joint,NEW tie rod ends/sleeves NEW control arm bumpers,All upper /lower control arms blasted and painted,NEW front wheel bearings,NEW brake and fuel lines,NEW gas tank and sending unit,NEW wiring harnesses, NEW dash pad,NEW carpet,rebuilt door hinges,ALL gauges work with NEW electronic voltage limiter,EL( electro luminescence) lighting repaired and working,Rotating Headlights work-all NEW relays. Headlights,tailights,turnsignals,interior lights ALL WORK, original radio repaired and works,Wiper motor works and have stainless wiper arms, NO rust in floors NO rust in frame rails very minimal rust in lower quarters,media blasted left quarter and trunk gutter,good glass,ALL window regulators work ,solid body with original paint,Door jams and engine bay and under hood painted,have all mouldings - including stainless rocker mouldings, have front bumper and brackets ,NEW 15" Firestone redline tires
