How long have you been using that brand of motor oil? Reason I ask is that IF the change has been of more recent vintage, then you are probably seeing the results of a better detergency additive package.
After watching some Lake Speed, Jr videos, it takes two full oil changes to get all of the old oil out of the system. Residual oil held in block passages, hydraulic lifters, and such. So any oil analysis would not be completely accurate due to your change of viscosities, even in the same brand and orientation of motor oil. YET only an oil analysis, multiple ones over time, can pinpoint bearing or cam lobe wear issues as to which "metals" are in the oil sample. Things you can't see by looking at the filter media in an oil filter.
To me, unless there are oil consumption issues with the 10W-30 oil in warmer weather, no reason to go to the heavier 20W-50 in the warmer months, up there.
I believe the FSM has a procedure to remove the oil pan "in car", but it is not easy to do. In the long run, it would be much easier to do what you might desire with the complete engine removed. Plus not having little drops of residual oil hitting you in the process. Or tax your shoulder muscles by always being under your work. Then taking a chance of messing up the new pan gasket on putting things back together "in car".
From s 1951 Plymouth FSM, it was mentioned that if the motor has ANY oil pressure at idle, that's fine. Of course, the only engine Plymouth used back then was the flathead 6-cyl.
If you perceive the main bearings to be wearing, as evidenced by the hot base idle oil pressure, consider that any oil being lost from between the bearings is being slung around the inside of the motor, including onto the cylinder walls. If the oil rings are worn a bit, they will not scrape the additional excess oil from the cylinder walls before the oil can migrate upward to the combustion chamber. Which means, basically, MORE oil consumption. That might be hard to document with 3K mile oil changes.
The OTHER thing is that unless you are getting a main bearing knock upon first start-up after the engine sits for a good while, no real need to worry about it.
To me, an engine oil analysis needs to have an oil sample that has more than 5K miles on it, up to about 6K miles, or when the oil hits "1 quart down" the first time, so the original oil is not diluted by fresh oil. Some oil labs will provide an extractor/retention device to remove the oil into a vial and then send the vial to them. No need to get it out of the drain plug stream when it's changed, that way. OR to have to wait for an oil change.
In the mean time, enjoy the car!
