furyus 67
Any thoughts on this one fellas? Bad tach,ignition..??? Has a small miss at about 3grand but nothing terrible. This ones got me stumped
Turn that volume on your computer up Stan!! That's was Bad company feel like makin looove!!! Won't catch much c&w coming from my speakers....maybe a lil cash, but that's about it!Turn off that damn C&W and it will sound better...
pretty sure they're in the "rock" category but it does have a country twang to it!;)I've seen the Grand Ole, Opry and I've met Johnny Cash. If that ain't country I'll kiss your ***.
^ what he said^You may want to add "I do not own the rights to the music in this video etc, etc." to your description so you don't get a copyright strike.
Thanks Dave. I'll look at that tomorrow. I thought I covered that but maybe not.Ground on ecu.
I'll try this here in a bit. The only reason I haven't gon after the coil or tach is because the problem did t exist when my 6al was hooked up. I put an orange box on and it wouldn't rev over 3k without breaking up terribly so I put the old ecu back. Kind of a lesser of two evils I guess. At least the old one its drivable lol. Thanks for the input .Unhook the tach. If it is reading differently then what the engine is actually doing that can cause ignition problems. Believe it or not a bad tach can cause a no spark condition. I've seen it way too many times. Also if it is doing it only under a heavy load I would be suspect of the coil. Typically a coil will have issues under heavier loads where the ecu will have it issues through out the entire range under any load. Also make sure you have a solid ground from the battery to the engine. A weak main ground can cause these types of issues.
You can make a ground wire to go from the mounting bolt and go to the head.Oh yea, adding a ground wire to the mounting bolts on the ecu didn't have any effect. Other than sanding the paint off of the fire wall, is there a better way to ground the ecu?
