WANTED Parts Needed
Those are just part type codes, with those you can find the part numbers and with luck find them on the internet.
Alan
24-24-170 Pad is in the A/C
24-24-164 Extension Button is in the A/C
21-30-26 Retainer For Automatic Transmission Pointer (Shows what gear you are in)
Any help would be appreciated, Thanks
What you've provided is the Group-Sub Group-Code. If you go to section 24 and scroll to the sub group and code you will see the part numbers for each car.
This link has the parts catalogs:
MyMopar - Mopar Forums & Information - Parts & Accessories Books
I appreciate it the info I was going crazy trying to figure out the numbers. Here are the numbers I found:
Dash Parts
Extension Push Button #2820 053
Pad #2864 649
Automatic Gear Selection
Gate #2950 146
Screw #6027 370
Indicator #2771 101
These will hopefully fix the problems on '68 Town & Country: the pointer in the shifter does not move and in a/c/heating unit will not go to defrost
Dash Parts
Pad #2864 649
Gate #2950 146
Screw #6027 370
Indicator #2771 101
I think you're definitely on the right track. A few points, you may want to consider, I would tear things apart before you start buying parts. It may be something has disconnected and not necessarily broke. You don't want to spend money you don't have to.
Do you have a service manual for your car? If not, that's a worth while expense.
Last point is someone on here should be able to tell you if a 68 T&C is a C1, C2, or C3. In this example, it doesn't matter but for other parts it will. I never checked what the difference was because I don't have a Chrysler.
