possibly silly question about V-Twin compressor on '66
darth_linux
Spokane, WA
So if I need to remove the AC compressor for some reason, is it possible to just unbolt the bracketry and "set it aside" like on newer cars, or do I have to evacuate the system and physically unbolt all of the connecting tubing, etc.? It seems like all of the connections are hard lines . . .
Thank you!
It all depends on how much you need to move it. If you are replacing a water pump or something, you should be able to lift it up a few inches without losing your freon.
You should find that info in your FSM.
