68monaco
Question. I have replaced my power steering pump with a correct federal pump recently and I'm having difficulty with steering resistance in a parking lot situation. It has the original steering box, not sure if I'm getting some of that resistance from it or not. High pressure line is also new. Is there a gauge for these to check pressure and if so what is the proper pressures? I have ordered a thinner fluid for racing applications to see if what I'm using, first ATF then Prestone, might be a little to thick.
