1Fury1
Slab Side Slacker
For 2 long years the fresh built 360 poly has been sitting waiting patiently for me to get everything else done. Finally the day is approaching where I will hear it run, maybe even this coming weekend since I have 4 days off.
The oil system should be primed which is something I've never seen done except for a chevy youtube. Would any of you experienced small block mopar hands have the play by play on removing the distributor and using a drill and a rod to turn the oil pump? The right rod to use? Oil pressure to expect? Other tips?
