polo62
do yall know if you can take out the rear frame and trunk and wheel houses out of a 68 fury 4 door sedan and install them in 68 fury fastopl thanks for any replys mark
Im pretty sure the rear frames and parts you describe are the same between the coupe and the four door. But unstitching every weld in each car then realigning it all in the new car before rewelding it all back in place is going to be a very big job.do yall know if you can take out the rear frame and trunk and wheel houses out of a 68 fury 4 door sedan and install them in 68 fury fastopl thanks for any replys mark
The pan/lap joint under rear seat area is were the wheelbase differences are made up, yes it can be done anything can be done.
Yeah I say go for it also and make a thread, lots of bracing. Alan not sure on c bodies but others have one inch difference in wheelbase two to four doors
