tbm3fan
So today was the day to put in new upper ball joints, pitman arm, idler arm, and both inner and outer tie rod ends. Should be a relatively easy job since I have all the tools from previous jobs. Should be?
First off when I pull out the socket for removing upper ball joints I see that it it too big for the old and new joints. Ok, first road block so let's move on. Pop the tie rods off the center link and knuckles. No problem and I clean up the shaft for the tie rods before putting the new ones in using the same dimensions as the old ones that came out. Put them aside .
Next pop the center link off the idler and pitman arms to clean up and put aside. The joint on the idler arm actually had 1" of vertical movement connected to the center link. Clearly it was shot. Getting the thing out went ok and see that the new one has 2 metal washers enclosed. Can see that they are supposed to go on either side of the idler arm between the mount. However, two of them are just a tad to thick to fit. Pull out a grade 8 9/16" washer which is a bit thinner and now the fit is good.
The pitman arm had me searching for anything that could remove a 1 1/2" nut. Found my giant crescent wrench and that worked. Yet once the arm was out it was very apparent that the new arm was 1" shorter than the original in there. Arm was a Raybestos professional grade arm that was made in the U.S. Now this seems to be a major problem. Can't put it in as the center link will not be horizontal under the car since the idler has the correct throw.
So the car sits in the driveway on jack stands unable to go to a car show this Saturday pending the pitman arm issue. Nothing ever goes smooth even when you have all the tools you think you need.
