This is unbelievable,, and he didn't end his one and only sentence with a .
THIS IS A 1973 CHRYSLER IMPERIAL 2 DR AND IT WAS PURCHASE AT AP CLARK CHRYSLER AND PLYMOUTH DEALERSHIP IN ORLANDO,FL IN 1973 AND I HAVE THE TITLE THAT IS DATE 1973 AND THE MANUAL AND THE GENTLEMAN PAST AWAY AND IT WENT TO A ESTATE AND HIS SON BOUGHT IT AND DIDN'T DRIVE IT THAT MUCH AND HE TOLD ME IT HAS BEEN STORED IN ENCLOSED GARAGE MOST OF LIKE AND ONE DAY HIS DAD GOT TO CLOSE TO GARAGE DOOR AND HIT THE SIDE OF DRIVER FRONT FENDER AND DOESN'T LOOK THAT BAD I JUST WANT TO BE HONEST ABOUT IT AND THE REST OF CAR IS REAL SOLID BECAUSE IT WAS STORE INSIDE MOST OF IT LIFE AND THE DOOR SHUT TIGHT AND THERE NO SAG IN THE DOOR AND TRUNK AND HOOD SHUT TIGHT AND LOOK LIKE IT HAS THE ORIGINAL PAINT AND VINYL TOP LOOK GOOD BUT WHERE THE CHROME MEET THE VINYL IN THE BACK WINDOW IS CURING UP IN PLACES AND INTERIOR LOOK NICE DOESN'T LOOK LIKE ANYBODY SAT IN THE BACK AND FRONT DRIVER IS SHOWING A LITTLE WEAR AND THE ELECTRIC WINDOW,SEAT,LOCK,ANTENNA WORK AND THE FRONT DOOR ON THE GRILLE OPEN BUT DON'T CLOSE I DON'T NO IF IT THE RELAY OR MOTOR BUT IT WORK MANUAL WAY ALL THE EXTERIOR LIGHT WORK AND THE TRUNK LIGHT WORK AND THE BUMPERS AND CHROME LOOK GOOD AND WHEN I GOT THE CAR I HAD TO DRAIN THE TANK AND CLEAN IT OUT AND BLOW OUT THE LINE AND REPLACE SOME OF THE RUBBER HOSES AND I PUT NEW FUEL PUMP AND NEW FUEL FILTER AND REBUILT CARB AND WIRE AND PLUG AND CHANGE OUT THE ANTI-FREEZE AND IT RUN COOL AND THE TRANSMISSION WAS CHANGE ABOUT 35,000 MILE AND SHIFT GOOD AND OIL PRESSURE LOOK GOOD AND IT DOESN'T SMOKE AND A/C IS NOT BLOWING COLD SO IT WILL NEED RECHARGE AND ASK ALL QUESTION BEFORE BIDDING AND WENT TODAY AND HAD THE OIL CHANGE AND THEY PUT IT ON THE RACK AND IINSPECTED THE FRAME RAIL AND FLOOR PANS AND CROSS MEMBER AND THEY WERE ROCK SOLID AND I HAD IT LUBE AND THEY CHECK THE FRONT END AND IT WAS TIGHT AND THEY CHECK THIRD MEMBER AND IT WAS FULL AND CLEAN AND THEY CHECK ALL THE BOLTS ON OIL PAN AND TRANSMISSION AND WHILE I HAD IT UP IN THE AIR I NOTICE A FEW DING BUT CAR LOOK STRAIGHT AND THERE SMALL DENT IN THE LOWER DRIVER QUARTER AND I ASK THE SON IF IT EVER BEEN PAINTED AND HE SAID NO AND HE HAD TOUCH UP SOME AREA ON CAR I WAS GOING TO PAINT IT BUT I WANTED TO KEEP IT ORIGINAL AND I HAVE A GAL HONEY GOLD PAINT THAT WILL GO WITH THE CAR AND WHERE THE CHROME TRIM ME THE VINYL TOP WAS FLIPPY UP SO I PULL IT BACK AND REGLUE AND THERE A SMALL TEAR IN VINYL WHERE IT MEET CHROME AND REST OF TOP LOOK GOOD AND FOR INTERIOR THE DOOR PANEL LOOK GOOD AND HEADLINER LOOK GREAT AND EVEN THE CLOCK, HEADLIGHT,KEY SWITCH SEAT BELT BUZZER STILL WORK AND LIGHT STILL WORK ON DOOR PANAL AND REAR PANEL STILL WORK AND I NOTICE THAT THE HORN DOESN'T WORK I WILL CHECK TO SEE IF THE FINS ON HORN NEED CLEAN ASK ALL QUESTION BEFORE BIDDING THANKS FOR LOOKING AND IF YOU LOCAL YOU COULD BY CHECK IT OUT DRIVE IT NO DISAPPOINTMENT I WLL PULL CAR OUT TOMORROW AND TAKE BETTER PICTURES IT WAS RAINING TODAY AND THE GAS GUAGE DOESN'T READ CORRECT IT A LITTLE OFF AND THIS IS 43 YEAR OLD CAR SO IT GOING TO HAVE A LITTLE WEAR AND TEAR AND IT HAS A FEW SCATCHES AND DING ANS DENT NOTHING MAJOR AND I HAD TO RELIST FOR NON PAYMENT PLEASE DON'T BID IF YOU DON'Y HAVE THE MONEY AND CAR IS IN GREAT SHAPE FOR IT AGE AND I WOULDN'T TAKE A LONG TRIP UNTIL YOU REPLACE THE TIRE THEY LOOK GOOD BUT THERE OLD AND SITTING LONG TIME AND I PLAY RADIO FOR THE FIRST TODAY AND PUT THE ANTENNA UP AND IT SOUND GOOD
