Yes, the fwd pin fits in a hole and the aft pin fits in a slot. You should be able to see these on the inside of the lip to verify. So, knock the skirt down on the aft side, letting it pivot at the front. I use a rubber mallet on the inside. I recall that when you jack up the body, you can remove the wheel while keeping the skirt on. As mentioned, regardless you must lift the body so the axle drops down enough to slide the wheel off.
