If you have high HC's then your car is a good indicator of poor combustion, Hydro Carbons are unburned fuel deposits.
Best thing to start with is your ignition system, a full tuneup would be a VERY good idea (new plugs, cap, wires, rotor, Points, etc) and make sure the plugs you purchase are in the correct heat range, and make sure they are correctly gaped.
Have the carb adjusted as High HC levels is usually a result of running Rich or lean
Check your vacuum, make sure vacuum is good and that all vacuum lines are good, Vacuum leaks can cause lean fuel ratio.
Replace the PCV (Positive Crankcase Ventilation) valve, if it's not flowing correctly it too can cause a Lean/Rich issue.
If after all that is done your still way over..............I hate to mention it but you may be experiencing bad rings.
Hope that helps.
Nick
