MightyMats
Good Morning fellow C-body members.
So I am having problems starting my 300 and im looking if anyone could give me some ideas as to why im having these problems.
Backstory: Two weeks ago or so I left my lights on and I killed the battery. Got a jump, drove it around for 30 minutes or so. Shut it off, turned it back on, perfect so i walked away. I went to start it later and nothing, no joy. Got a jump thinking the battery might have been junk and still nothing. I determined with a multi-meter that it was an electrical problem.
I thought the fusable link was trash so i pulled it apart to find that it wasnt. So i made a new one (same length and wire gauge). I wasn't getting power to the started solenoid so i took all the connections off, cleaned them and then got power to the firewall. Still didn't start. I took all the connections off the firewall, cleaned them all out and filled them up with grease, still didnt start. I replaced the ground wire off the battery because it was corroded, still nothing. Then I went under the dash and determined that I am not getting power to the key. So somewhere between where the key and the firewall is where my circuit is broken. I have power coming out of the firewall into the cab.
I do not have headlights or lights in the car when i open the door. My horn does work and so does my power seat. I hooked up a wire from the ballast resistor going to the battery that way I got 12 volts (9 volts) to the distributor. Then I took a screwdriver and connected the power post on the starter solenoid to the starter wire and I started the car. Now I can drive the car if I need to (obviously being mindful of the electrical hazard I just created).
My question is what am I missing between the firewall and the key. Its really hard to see upside down and im having a hard time getting my hands behind the dash. Any help would be appreciated.
Thanks
Thanks
