polara383500
Just was asking can you buy 440 source stealth heads and bolt them on with stock rockers and stock push rods
Yes on the rockers(actually states it on their site) and should be able to use same push rods but I would check length anyways on the pushrods. IMO the promaxx heads are a better value. They have better machine work from the factory including the valve job AND you can choose springs that fit your cam/lifter specs rather than the off the shelf springs that come on the stealth heads which may or may not work well with your cam/lifters requiring an extra expense to swap. Promaxx you can run anything from stamped stock rockers to full roller but would also check pushrod length fitment on these as wellJust was asking can you buy 440 source stealth heads and bolt them on with stock rockers and stock push rods
